It is currently Fri Aug 08, 2025 3:36 am
 Post subject: binding with koa
PostPosted: Tue May 01, 2018 1:48 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I'm trying to decide what kind of binding to use with curly koa back & sides. I've go a selection of most species. Pics are always appreciated
Mike McNerney
 Post subject: Re: binding with koa
PostPosted: Tue May 01, 2018 2:14 pm
i would consider curly maple with b/w/b. i don't do shell, but you could purf that with some black on either side.
fwiw, i make short 1 inch long binding and purfling combo "stubs" for tryout and checking rebate dimensions. makes choosing a bit easier.
These users thanked the author arie for the post: Jonny (Wed May 02, 2018 8:41 am)
PostPosted: Tue May 01, 2018 2:48 pm
Last Name: Kincheloe
For some hue contrast, purple looks good next to orange. Either purpleheart, camatillo rosewood, or bois de rose (although it's nearly black). Green might also be interesting, so lignum vitae, verawood, or greenheart. Ziricote is also a bit on the green side, though less striking. Indian rosewood or curly maple would also be good for a more tame look. Spalted maple would look good, though would need to be drowned in thin CA to harden it up.
PostPosted: Tue May 01, 2018 3:25 pm
First name: Heath
Last Name: Blair
City: Visalia
What are the fretboard/bridge/headplate materials?
sweat the small stuff.
PostPosted: Tue May 01, 2018 3:58 pm
Last Name: Beaver
City: Lake Forest
i have used curly eucalyptus. It's good if you want to go subtle.
Joe Beaver
Maker of Sawdust
PostPosted: Tue May 01, 2018 4:43 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I'm thinking African blackwood bridge, head plate, fret board. I did use lignum vitae binding on a uke last year & it bent easily. & maybe that Argentinian ironwood for the bridge.
Mike McNerney
PostPosted: Tue May 01, 2018 4:49 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Somewhere there was a pictorial library of binding/purfling schemes.
Anyone remeber where?
PostPosted: Tue May 01, 2018 5:16 pm
City: Tyler
Blood wood looks great.
PostPosted: Tue May 01, 2018 5:25 pm
"I'm thinking African blackwood bridge, head plate, fret board."
Black plastic....
PostPosted: Tue May 01, 2018 5:39 pm
First name: Freeman
Last Name: Keller
For flamed koa I like flamed maple
If its not flamed I like not very flamed maple
Throw on a black accent line to set them off
These users thanked the author Freeman for the post: ernie (Wed May 02, 2018 7:11 am)
PostPosted: Tue May 01, 2018 5:50 pm
How is the color on the lignum holding out?
Sent from my SM-N910T using Tapatalk
PostPosted: Tue May 01, 2018 8:36 pm
First name: Aaron
I've done a few Koa bindings recently. I like the looks. So do the clients.
PostPosted: Wed May 02, 2018 12:31 am
Last Name: Beaver
City: Lake Forest
African blackwood might look pretty good. I am currently building two EIR guitars and one macassar ebony. I'm thinking of using macassar ebony to bind at least the ebony guitar, maybe all three. Dark can be good
Joe Beaver
Maker of Sawdust
PostPosted: Wed May 02, 2018 5:57 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
how does curly koa bend & and how thick can you make it. The lignum is still a nice green.
Mike McNerney
These users thanked the author mikemcnerney for the post: Pmaj7 (Wed May 02, 2018 2:31 pm)
PostPosted: Fri May 04, 2018 8:36 pm
Koa Binding
PostPosted: Sat May 05, 2018 6:42 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We apply purfling to curly koa at .090", then thin to .078" for bending. No special techniques for koa, other than as with any other lower hardness wood, which is to say that we ensure that the bender ram does not compress the wood (we use .078" x 32" x 1.75" sacrificial filler strips of whatever scrap is handy on either side of the binding packages to ensure the pressure at the waist or in the cutaway area is even). Supersoft II works well with koa, but we usually don't use it on bindings due to the possibility of discoloration of the bindings due to the mobility of the water and glycol-soluble extractives. Koa can discolor badly if any aluminum comes in contact with the wet wood, causing a blue/green stain, so the same kraft paper we use for the moisture reservoir in the bending package does double duty as a barrier.
- Beth Brower
PostPosted: Mon May 07, 2018 5:27 pm
State: PA
Curly koa bindings with Australian blackwood.
PostPosted: Mon May 07, 2018 5:31 pm
perhaps I'm totally missing the point, but I'm pretty sure the OP wants binding choices for a koa bodied guitar, not for advice on how to bend curly koa...
that being said, I rather like the black plastic binding on my '86 Taylor K20...of course I'm not recommending plastic as binding, but I think ebony, African blackwood, or similar would look nice.
Users browsing this forum: No registered users and 42 guests
